Knew I had read it some where:
http://autopia.org/f...x-your-car.html
* Work in a shaded area out of direct sunlight.
* Use a foam applicator pad to apply your wax. When the applicator becomes caked with wax, switch to a fresh applicator.
* Work on one area at a time covering 2 to 4 square feet. Some products may allow you to coat the entire car before buffing off, but most do not.
* Follow the wax manufacturer's instructions on whether or not to allow the wax to dry (haze) before buffing.
* Use a small amount of wax at a time, and rub it in well. If you use too much wax, you're wasting the product and your time.
* If the wax residue does not buff off easily, switch to a clean wipe towel.
* Apply your wax in a back-and-forth motion, not in circles. If you are creating swirls, you need to replace your applicator or towels.
