Peter L
January 14, 2004, 4:29 pm
Anybody know what it is and if wheels on an RX300 will fit ?
Cheers ...
Peter L
January 15, 2004, 12:58 pm
S'alright - I've found it out meself, if anybody wants to know it's :-
16x6.5", 5x114.3, ET 35, 225/70/16, 60.1 CB and both LS and RX wheels are the same as GS wheels.
ColinBarber
January 15, 2004, 8:45 pm
Your thread title refers to 18" sport wheels and this information is for 16" standard wheels???
Peter L
January 15, 2004, 11:00 pm
Colin - info was 'copied' from a site, doesn't matter as long as correct offset - didn't see anybody spring to help when I asked the question though ...
ColinBarber
January 16, 2004, 8:51 am
But the offset will change with the width of the rim. The 18" rims are wider than the 16" ones.
Peter L
January 16, 2004, 1:03 pm
I think that you'll find that if it's the correct offset then size shouldn't matter the ET will often be quoted within a range e.g. in this case ET35... 42 regardless of size which in this case all GS/LS/RX have the same ET of between 35 ... 42
ColinBarber
January 16, 2004, 1:27 pm
Spec of the wheels can be found on the TTE site follow this link and click on the AM links
[url="http://www.tte.de/tuning/website/Accessories/accessories-lexus-gs300-s16.html#Lexus"]http://www.tte.de/tuning/website/Accessori...-s16.html#Lexus[/url] GS300 S16 wheel and tyre kit
Peter L
January 16, 2004, 4:17 pm
Thanks Colin - confirmation of 5x114.3 but does not mention ET (or have I mised it ?)
Cheers again
andyhart21
January 16, 2004, 5:17 pm
[quote name='ColinBarber' date='Jan 16 2004, 08:51 AM']But the offset will change with the width of the rim. The 18" rims are wider than the 16" ones.[/quote]
The offset is the distance from the centre line of the wheel to the wheel mounting face.
If the mounting face of the wheel is closer to the car than the centre line of the wheel (as in a lot of deep dish wheels), then this is a negative offset.
If the mounting face of the wheel is further away from the car than the centre line of the wheel (as most if not all Lexus wheels are), this is a positive offset.
The number is the offset distance in millimetres. I am not sure what the ET stands for but I think it is just some sort of abreviation for offset. In theory, as long as the offset is the same, wider wheels should not be a problem. The things you have to watch out for with wider wheels are arch clearance and suspension component clearance.
ColinBarber
January 16, 2004, 8:17 pm
[quote name='Peter L' date='Jan 16 2004, 04:17 PM']Thanks Colin - confirmation of 5x114.3 but does not mention ET (or have I mised it ?)
Cheers again[/quote]
I think it's in there, EinpreBtiefe ??
click here.
