zxtt
Jan 17 2004, 04:21 PM
idle seems to low will resetting the ecu sort this out if so how do you resett it is it the same as my zed
cheers gs300 1997
zxtt
Jan 17 2004, 05:41 PM
found the info resett it idle seems better is it learning ecu if so will take it out and cane the granny out of her when its nice and cold
ColinBarber
Jan 17 2004, 09:18 PM
You may find the idle will go back to how it was. You may want to get the throttle body cleaned and the Throttle position sensor checked and adjusted correctly.
zxtt
Jan 18 2004, 08:25 AM
