Steve
Jan 1 2002, 10:07 PM
The pictures have been lost in this thread... please head here for an update of this
http://www.lexusownersclub.com/us/forums/i...t=ST&f=14&t=21&thanks
I am adding a few more pictures on how to remove your stereo unit. I found it quite easy to remove as i needed to take out the unit so I could place a band expander on the back of the Stereo as I could not receive all radio channels due to the car being imported from japan and the radio only ever picked up one radio channel.
Here is the first part
First you have to remove the air vent as shown in the picture below. Inside the air vent you shall find two clips (bottom of the vent). You have to push these clips down with a screwdriver to release the Stereo unit. When the clips pop out you then have to carefully pull the air vent out. Also the air vent is a little tight.
Steve
Then you hav to undo the screws below the stereo... this is covered by a black plastic strip... this pops off with a bit of a tug
Steve
Jan 1 2002, 10:08 PM
Give your stereo a tug and out she pops... you may have to jiggle a bit as the brackets get in the way a little
Steve
Jan 1 2002, 10:09 PM
Here is a shot of the side of the stereo
Once the stereo is out you will have a lots of room to play with.
TIP: make sure you place a cloth on top of your walnet console.. or you may scratch the wood effect by your transmission lever. As you can see here i did not.. but i did soon after i realised that it was make a scratch :smilegrin:
sumsingh
May 19 2002, 11:25 AM
I'm stumped -- How do I remove the center air vents for the ES300?
Steve
May 19 2002, 04:51 PM
look inside your vents with a torch an on the bottom lip on the vent you will see two clips... push a screw driver in this and the clips will pop out... once you have popped both clips simply wiggle the vent out.
Tek7
Jun 18 2003, 09:52 PM
Can anyone tell me where I can purchase a stereo filler to match my walnet/wood finish (is the same as seen on the pics above) in case I'd change my OG stereo with one at a stereo shop? Or if a ES300 '95 stereo has a remote wire I can use to pass remote an external amp (Kenwood, Alpine, etc)?
Thanks!
Steve
Jun 18 2003, 10:55 PM
try autotoys.com
click here.
