pcroland
February 18, 2004, 4:39 am
Hey all,
driver's side front wheel seized up today, one of the pistons is stuck, '93 GS00 ..any ideas on a solution besides buying a stock caliper at the dealer?
...saw a few websites that sell the piston seperately, does this mean the bad piston can be replaced? is it a DIY job?
Are there any after market calipers out there for our first gen GS?
Thanks,
Roland
DaveEllen
February 18, 2004, 8:08 am
I've had this problem on older cars...........taking the caliper off using lots of WD40 has normally helped until I can get a new caliper
billy boy
February 18, 2004, 8:38 pm
Had the same problem with my 95 GS 300 Sport I removed the pads pushed the caliper piston out as far as I dare cleaned with WD 40 and some light emery paper smeared with copper slip and pushed thepiston back in cleaned excess off and it was ok after that Hope this helps PS now the owner of an Arito 300v twin turbo Graet car Billy Boy
Rob
February 18, 2004, 8:43 pm
i would avoid using excessive amount of oil based lubricant on the brake pistons as this can lead to undetectable damage to the piston seal - get yourself some silicone grease - its a whitish compound, this is safe for use on rubber seals - apply this to the vescalised (sp) portion of the piston ( the chrome bit) and work the piston in and out - that may or may not solve your problem.
pcroland
February 19, 2004, 1:32 am
..thanks for the responses
...after close inspection, the caliper seemed to be in pretty bad shape, so just opted for a remanufactured caliper, paid $58 + my old caliper.
..so far it's working pretty good.
Roland
randyreindeer
February 20, 2004, 3:25 pm
I had the same problem and it caused the steering wheel to vibrate at low speeds.
It would be wise to check the other side as well.
click here.
