[quote name='altezzaz' date='May 19 2005, 10:13 PM']eh? Toyota put it there in the first place.... I think you'll find that the mark 2 MR2 has the same problem, just not as pronounced
[right][snapback]245191[/snapback][/right][/quote]
That's true, they did put the noise there, but my dealer has no idea where it comes from and doesn't want to go replacing expensive parts only to find that it hasn't helped... Not a particularly good customer service attitude...
I'll just have to convince them that the gearbox is the problem, get a new one, and then get them to do something about what now appears to be the source - the engine. Perhaps replacement with a 2JZ would help?
Interesting point about the MR2s, I'll have to look into that some more. I've got a few intake tweaks (playing with vacuum hoses, fuel mixtures etc) that I will try to see if they have an effect.
I've been trying to study what the ECU does around the time the rumble occurs, things like the deceleration fuel cut point and closed loop vs open loop fuel ratio control to see if any of these influence the rumble.
