Full Version: Vibration Shifting Sometimes
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club > Engine & Transmission
deedee
Hiya
I have a mk1 gs300 sport 97... If i am driving along and pull the shifter from d to 2 or 1 for engine braking i get a fairly big viberation and a tiny noise... Likewise if i come to a stop and put it in to Reverse and i also get the same vibration... It doesnt happen everytime but quite alot... I just wanted to know if anyone has ever heard or had the same problem and would know what it is or what to check...
With Thanks
ColinBarber
For a start have you checked the transmission fluild level?
deedee
Thanks colin i will check the level i am waiting for a lexus cd should be here in the next few days... Thanks for both replies...
deedee
Ok man i checked the level it was ok.... Anything else you can think of that could be causing the problem...
Whitebeam
Worth checking the engine & transmission mounts. With the engine off & transmission in Park (so its locked), release the handbrake and rock the car back & forwards (only try this on level ground). Listen for strange noises.
deedee
HIya
The dipstick on for the gearbox oil is strange so i checked it again... On mine it says HOT and COOL point is when i checked it and it had not be started for a few days the oil was just under the top nic for HOT... If this make since to you what does that mean... I thought it should be down the bottom at the top nic of the COOL...
Oh yea there is no noise when i rocked it back and forth... Any other suggestions...
With Thanks
punash007
[quote name='deedee' post='122976' date='Mar 17 2004, 06:02 AM']HIya
With Thanks[/quote]
Hello,
I have the same problem wth my 1994 GS300, I have'nt solve the problem as yet and I notice that the posting was in 2004. Can you please say if you solve the issue and if so, what was the cause. Thanks in advance as I look forward t your response.
Full Colour Version: Vibration Shifting Sometimes
