AltezzaScott
Mar 10 2004, 11:25 AM
OK, i have clunking once again!! on the front brakes.
Having taken the wheel off and inspecting the disc, hub, caliper etc..... There is about a mm gap each side of the hole in the disc where the studs come through, thus enabling you to be able to move the hub ( by pushing the studs ) about a mm before coming into contact with the disc.... i was wondering if this is what is causing the clunking... or is this normal?
thanks gents
DaveEllen
Mar 10 2004, 11:29 AM
doesnt sound quite right to me.....
Colin.......where are you ?
TonyGoose
Mar 10 2004, 11:37 AM
More likely to be the pads moving in the caliper bracket.
Lexus have issued a tech bulletin to their dealers about it.
Fargo
Mar 10 2004, 11:54 AM
is it when you brake,, may be the pads moving.. copper slip sorts the noise out..
ColinBarber
Mar 10 2004, 12:23 PM
Have a look here. Not for the IS but the same problem and cure.
http://www.alldatadiy.com/alldata/AFI~G~C2...063452/82905304Please note this link may not work in the future as alldatadiy change the demo vehicle now and again.
AltezzaScott
Mar 10 2004, 12:36 PM
Thanks, so should i take it that this little mm gap is normal??
ColinBarber
Mar 10 2004, 01:15 PM
I think the gap is normal.
Rob
Mar 10 2004, 03:19 PM
Hi Scott,
Yes that little gap is perfectly normal, the clunk sound that u are hearing is the pads touching the caliper framework - put a tiny bit of copper or ceramic grease on the end tangs of the pads and the noise will stop.
click here.
