julian2002
Jul 23 2002, 01:02 AM
hi,
one of the headlight bulbs on my '91 ls 400 has popped so i'd like to replace all of them (to be on the safe side) however i'd also like a bit more 'oomph' to the intensity of the light produced. has anyone got a suggestion as to what to replace them with? the funky coloured bulbs are out as they are actually dimmer as well as being illegal
a slight over wattage is ok but huge wattages that will melt the car in front;s bumper and blind drivers in the next county are also a no-no..
also what type of bulbs are standard?
cheers
julian
Shrek
Jul 23 2002, 05:54 AM
Welcome to the club Julian
check out the PiAA website they have everything you could wish for bulb wise.
www.piaa.co.uk Happy hunting mate
Les
Zee007
Jul 23 2002, 07:55 AM
Welcome to the club Julian!
Another good alternative are Phillips bulbs - a lot of us have the blue vision which are 30% brighter than standard but with a whiter light (like HID)... Good luck mate... :tumble:
julian2002
Jul 23 2002, 09:02 AM
thanks for the suggestions i'm going to have a poke around the local motoring stores this afternoon....
cheers
julian.
julianr07103
Aug 2 2003, 07:13 AM
you might want to go with a real hid conversion kit. it is relatively simple to install and costs about $300, or check ebay and they pop up for $100 every so often.
rhaines
Aug 2 2003, 08:19 AM
There should be a GB coming soon on HID conversion kit's I'm waiting on the costings and informat6ion now
Chris.S
Aug 2 2003, 10:27 AM
Try
www.powerbulbs.com they have quite a selection
flotsam
Aug 2 2003, 11:44 PM
If you want a brighter beam, then HID kit is probably the way to go. They should use less current so you shouldn't have to worry there.
If you do go this route stick to the 4100K bulbs. HID is capable of precise beam patterns and you should see a sharp cut-off with natural sunlight-like illumination.
Higher colour temperature bulbs which go into the blue not only diffuse more ruining the pattern and blinding oncoming traffic, but also cause eye fatigue as they burn into the retina more (as will the oncoming driver's main beams).
click here.
