Full Version: Can Tire Pressure Sensors Pressure Be Reset?
Lexus Owners Club > Lexus Models > SC Model
bly
Does anyone know if the preset presure alert points can be adjusted on the tire pressure sensors. The manual says they alert at 26lbs and flash alert at 14. Can they be reset to different pressure?
Curran
I work for a company that designs systems to either read the tire pressure monitors on tire lines eg tmp, wheel or car production lines.
As far as I know from the data sheets I have seen there are none where you can adjust the pressure limits eg its all set by the manufacturer.
