QUOTE(spikus1969 @ Oct 5 2004, 04:13 PM)
QUOTE(maneesh @ Sep 4 2004, 07:21 AM)
Dude,
With an 8 year old car why pay main dealer prices?????
Changing brake discs and pads on a 1996 LS400 is not rocket science, any decent garage should be able to do it for you.
I thought Brembo upgrade kits for the LS400 cost upwards of £2000.
I would stick with OEM. However, US discs should fit UK cars. Just bear in mind that the pads and discs sold in the US MAY be slightly different to UK spec, although you would have to check.
There are numerous sellers on ebay selling cheap LS400 discs. Look there maybe.
Even Kwik-Fit will be able to do your pads and discs. They would use Mintex products.
You could always change them yourself if you have the time and inclination..
See www.lexls.com under tutorials section
if you are looking for aftermarket brake products try these order them online from the comfort of your chair and delivered to your door.....try fitting them yourself quite easy really
www.ebcbrakes4u.co.uk
[snapback]174066[/snapback]
Dear All,
Please can I have your opinions and feedback?
I have recently aquirred a 98 MK4 LS400 it will shortly require a full set of Discs and of course pads.
I will be fitting them, and could go down the original equipment route, although having owned other LS400's I have reservations due to seemingly rapid wear of both discs and pads, and the accompanying dust emission and wheel corrosion problems.
I have scoured the owners site for an definative answer to no avail and am now asking for your direct opinions and experiences.
I am not adverse to fitting aftermarket items (and have read before but can't find it now) that several companies use Brembo blanks and finish and retail them themselves, any knowledge?
We drive the car very sedately so extreme performance is not required.
Please would you give me your views on EBC, Mintex, Delphi and any other makes available that you have experience of?
I have been looking within the USA and found a set (4) of Brembo's for $308 (yes these are for a UK car) but with $195 shipping (surface carrier, air was a joke), import tax and of course VAT the attraction has been taken away!
Please respond.
Best regards,
Chris Vince
