taspland
September 7, 2004, 6:57 pm
I am the v proud owner of a Aristo TT '95. However the vehicle does not have a owners hand book and I was wondering what the Auto Airpwr button near the centre console arm rest does? Also when the little engine light comes up what does that exatcly mean, service due? or more serious?
Many thanks
Tom from Surrey
KELLTINA
September 7, 2004, 7:16 pm
Hi Taspland,what i can tell you is on the uk spec car,the PWR switch when switched on followed by a light on the dash,it will hold your car in its gears for a longer period rather than changing gear at lower revs.
taspland
September 7, 2004, 9:31 pm
[quote name='KELLTINA' date='Sep 7 2004, 07:16 PM']Hi Taspland,what i can tell you is on the uk spec car,the PWR switch when switched on followed by a light on the dash,it will hold your car in its gears for a longer period rather than changing gear at lower revs.[/quote]
I dont think thats the switch that I need to know about, the one you are referring to is the ECT switch for the autotrans mode toggle. I have a switch that has Off, low, high, and other setting but has the title Auto AirPwr.
Tom
norkep
September 8, 2004, 7:53 am
Hi Tom,
The toggle you'r on about is the "Auto Air Purefier", this will filter the incar carpartment, the filter is in the boot on the right hand side. It works with the fan controls, if you leave it on "Auto", it will speed up and slow down with the speeds of the fans. If on Low or High, it's then in all the time. The fans for this are located on the rear parcel shelf under what looks like speaker grills, one left and one right - either side of the centre sub.
The engine light can be caused by a lots of things from loss of pressure in the coolent to an ECU error for firing. As far as servicing, you should have the oil done every 6 months ideally, the rest can be done once a year depending on milage.
I'm in the middle of getting a manual sorted out for these, takes a time due to translation required for this.
Nice to have another Aristo in the Club - Welcome
BR
Paul
dangerous brain
August 8, 2005, 9:58 pm
What was the cause of the engine light?
taspland
August 9, 2005, 3:41 pm
[quote name='dangerous brain' date='Aug 8 2005, 09:58 PM']What was the cause of the engine light?
[right][snapback]271473[/snapback][/right][/quote]
That was the faulty speed sensor. ECU was all confused. as you can see in the vid everything is clear when started.
click here.
