Full Version: Clickety Click - my clutch pedal's sick
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Engine & Transmission
Div
I've just noticed a clicking noise from my clutch pedal - after depressing it about an inch there's a single distinct click. Anyone know what it might be before I take it to the dealers?
Cheers,
Div.
JOHNNY-BOY
Does it happen every time you press your clutch pedal?
Blue Thunder
Yup I had the exact same problem. First diagnosed as the pedal hitting the overmats, but I had "modified mats" apparently so that wasnt the problem??!!
I then had a new master cylinder fitted................ that didnt work, then they fitted a new clutch pedal assembly and that did the trick, so yes get it to your dealer. Tyhey didnt tell me what it was but I think it was a bearing on the pedal shaft or something
Grangey
Mines in tomorrow for a new pedal bush. It makes more of a creaking noise when you press it, though.
Grangey
QUOTE
Originally posted by GRiM
Would any of you guys mind posting your mileage when these problems occured, just in case it's something we all should look out for.
13,000
Claire G
My clutch pedal made a creaking noise from brand new - it took a couple of trips to my Lexus dealership before it got sorted. Not sure exactly what it was but took some heavy duty WD40'ing !
Div
Mines just over the 60,000 mark, I olny bought it three weeks ago from Guildford Lexus - and this problem was flagged by the RAC check - they said they'd fixed it though. I've a feeling that 'fixed' involved WD40. Guildford's a good 40mins away, so I'll perhaps see if I can get it into Reading, but I feel a bit cheeky as it's Guildfords problem.
Yeah it does happen every time - and it's a very definate click.
Blue Thunder
Mine started at about 8000 miles. I think in the end it was the bush causing the problem but by then they had replaced most of it!!
My car was sorted by Guildford, and they did a cracking job
lexicon
Mine had a clicking clutch pedal when it was about three weeks old - the pedal was catching on the bulkhead carpet (not the mat). The dealer "modified" it with a stanley knife and then said "Yeah, they do that if you push the pedal all the way down" - like it was my fault!!
Chris.S
My pedal creaked when it was brand new,I had it adjusted and greased and it has never done it again
