aido
Oct 12 2004, 01:57 PM
OK, I see over on IS300.net lately they aren't recommending really stiff sway bars for use with coilovers, as it tightens the car up too much so you lose handling performance etc and increase the risk of oversteer (or maybe it's returning the car to neutral values?) Can't remember but it was said it could cause detrimental effects...
They say the yellow TRDs which some of us have are pretty much at the limit to be used in conjunction with coilovers, so I thought I'd ask this question, what combos of coilover & sways (antiroll bars) are you guys using, and if you're using adjustable sways what setting have you got them on, ie soft, middle, hard etc....
I'm running the TRD Yellow Race spec sways and Zee's TTE Coilovers, and to me the car seems fantastic handling wise so I'm not sure what the guys over there mean...
I'm also interested in doing one of those days where you spend a few hours in a skid pad and learn how to control understeer and oversteer, that's kind of linked to this, any of you guys done anything like that? I just need to lose a few stone before they'll let me near it!!!!
TIA
Results so far:
Aido: TTE Coilovers, TRD Race Sways (Hard)
Dave Ellen: Tein Flex Coilovers, TTE Sways (Medium)
Scorpion: Tein SS Coilovers, TTE Sways (Medium)
Fargo: Apexi Type V N1 Coilovers, TTE Sways (Hard)
Tony Goose: TTE Coilovers, TTE Sways (Medium)
Bazza: Tein Coilovers, TRD Race Sways (Hard)
Maz: Tein Coilovers, TTE Sways (Unknown)
Dark_IS200: HKS Hiper Coilovers, HKS Sways (Hard)
SteveAudioX: Tein NA Coilovers, TTE Sways (Hard)
Mat C: White Car: HKS Hiper Coilovers, TRD Race Sways (Hard)
Mat C: Black Car: TTE Coilovers, TTE Sways (Hard)
Duncan: TTE Coilovers, TTE Sways (Hard)
ProLex-UK
Oct 12 2004, 02:09 PM
The Prolex-uk mobile is on TTE anti roll bars and TEIN Flex coilovers with EDFC
Also got the full TRD uprated bushes on
aido
Oct 12 2004, 02:19 PM
What settings have you got the TTE's on Dave?
So that's:
Dave: Tein Flex, TTE Sway Bars (Medium)
ProLex-UK
Oct 12 2004, 02:21 PM
Only the rears are adjustable...they are on the middle adjustment
Mr Singh
Oct 12 2004, 03:01 PM
My Knowledge on sway bars are somewhat limited. What do they do?
aido
Oct 12 2004, 03:05 PM
Basically I think they tighten up both ends of the suspension so there is less flex, which results in less body roll being felt in the car, you really notice this when going round hard corners, but it's also noticable with any steering you do, you'll have minimised roll with the coilovers but the sway's just increase this reduction (does that make sense?!). I think because there's less roll the back end is more likely to jump out (oversteer I think) as the chassis can't absorb as much any more since the sways keep things under control.
Mat C has the best explanation of all things suspension related, it's all a bit confusing for me!
Scorpion
Oct 12 2004, 03:25 PM
TeinSS with TTE front/rear bars......handles like a dream
aido
Oct 12 2004, 03:27 PM
What adjustment are you on the rear TTE's Pete?
Scorpion
Oct 12 2004, 03:28 PM
QUOTE(aido @ Oct 12 2004, 04:27 PM)
Middle..
Fargo
Oct 12 2004, 03:38 PM
apexi type v N1's
TTE hard..
front top strut brace
one point though aido,, if TTE supply both antiroll bars and c/o's i would have thought they had been fully tested as a combination and so do not affect the car as the .Net'ers are saying..
Scorpion
Oct 12 2004, 03:42 PM
Yanks cant drive fast..
aido
Oct 12 2004, 04:10 PM
They're on about bars which are even stiffer than the TRD Yellows (which I think are stiffer than the TTEs even on the hardest setting?!)
I just saw one of the comments saying that the TRD Yellows were about as hard as you should get with coilovers and it made me think!
Mr Singh
Oct 12 2004, 04:17 PM
QUOTE(aido @ Oct 12 2004, 04:05 PM)
Makes perfect sense. I would do it, but not if it will comprimise ride quality. Loving mine at the mo
aido
Doesn't affect ride quality at all mate, just reduces the roll you get around corners, there's a corner near me which you can only normally take at 15-20 (U bend) but with the coilovers and sways you can chuck her round and be accellerating while you're at it (only in the dry though!!!)
necromax
Oct 12 2004, 04:51 PM
How an Anti-Roll Bar Works
Put simply, an anti-roll bar is a U-shaped metal bar that links both wheels on the same axle to the chassis. Essentially, the ends of the bar are connected to the suspension while the center of the bar is connected to the body of the car.
In order for body roll to occur, the suspension on the outside edge of the car must compress while the suspension on the inside edge simultaneously extends. However, since the anti-roll bar is attached to both wheels, such movement is only possible if the metal bar is allowed to twist. (One side of the bar must twist upward while the other twists downward.) So the bar's torsional stiffness-or resistance to twist-determines its ability to reduce body roll. Less twisting of the bar results in less movement into jounce and rebound by the opposite ends of the suspension-which results in less body roll.
necromax
Oct 12 2004, 05:02 PM
Reduced body roll can lead to a reduction in adverse camber changes for better tyre traction, BUT will also increase oversteer....
I'm hoping to go end up with same setup as Dave.. Tein Flex with EFDC, TTE anti-roll bars.
Scorpion
Oct 12 2004, 05:04 PM
Oversteer is fun
Gets the a**e end out
Mr Singh
Oct 12 2004, 05:22 PM
I'm still trying to get to grips with oversteer, In the Wet that is
Sways are added to my list of 'do's
TonyGoose
Oct 12 2004, 05:43 PM
TTE and errr TTE (middle)
I'm happy with that at the mo - might tighten the bars sometime...
Americans talking about this you say ??
When did they get corners ?? Heavens, they'll have roundabouts next
Bazza
Oct 12 2004, 05:47 PM
teins
trd
aido
Oct 12 2004, 05:50 PM
I've got to admit I'm quite surprised at this so far, I'd just taken it for granted that all of you lot with the TTE bars had stuck them onto the hardest setting!
We'll have to try a comparison next time I see you all
Maz
Oct 12 2004, 10:33 PM
dark_is200
Oct 12 2004, 11:06 PM
HKS hiper dampers
HKS anti-roll bars
Cusco strut braces
SteveAudioX
Oct 13 2004, 08:56 PM
Tein coilovers NA type 16 damping settings setting on 7 from softest
TTE anti roll bars Stiff settings on rears (only available adjustments on rears)
Cusco upper front strut brace..
Car handles great ...If tracked correctly, thought I'd stress that point.
Monster-Mat
Oct 13 2004, 09:05 PM
Monster......... HKS Hipermax II and TRD yellows (hard settings)
race car.........TTE coilovers, harder springs, TTE bars, hard setting
aido
Oct 13 2004, 09:10 PM
Sounds like we have a good mixture, any of you guys have any issues with handling?
Got to admit I'm more than happy with the car, she's so much better than stock now, can't really imagine ever going back to standard!!
Mat, what improvements did you see with the uprated springs for the TTE coilovers? Is it mainly improvements for race use or would you recommend them for a daily driver?
Cheers
Monster-Mat
Oct 13 2004, 09:13 PM
QUOTE(aido @ Oct 13 2004, 11:10 PM)
Cheers
they are not recomended for road use, they are basically springs i had wound at Suplex for me, they are 20mm shorter and 37% stiffer than the std TTE springs, on the rear and 42% stiffer on the front
DUNCAN
Oct 14 2004, 04:09 PM
TTE coilovers and TTE sway's (hard)
click here.
