[u][b]Endorsement Offence Codes + Points[/b][/u]
Endorsements remain on a counterpart licence for:
* 11 years from date of conviction for offences relating to drink/drugs
and driving, causing death by careless driving whilst under the
influence of drink/drugs and causing death by careless driving then
failing to provide a specimen for analysis
* 4 years from date of conviction for reckless/dangerous driving and
offences resulting in disqualification
* 4 years from the date of offence in all other cases
Please note, in addition to the endorsement points, you will also receive a fine.
[u][b]Accident Offences[/b][/u]
AC10 Failing to stop after an accident.......... 5-10
AC20 Failing to give particulars or to report an accident within 24 hours.......... 5-10
AC30 Undefined accident offences.......... 4-9
[u][b]Disqualified Driver[/b][/u]
BA10 Driving whilst disqualified by order of court.......... 6
BA30 Attempting to drive while disqualified by order of court.......... 6
[u][b]Careless Driving[/b][/u]
CD10 Driving without due care and attention.......... 3-9
CD20 Driving without reasonable consideration for other road users.......... 3-9
CD30 Driving without due care and attention or without reasonable consideration for other road users.......... 3-9
CD40 Causing death through careless driving when unfit through drink.......... 3-11
CD50 Causing death by careless driving when unfit through drugs.......... 3-11
CD60 Causing death by careless driving with alcohol level above the limit.......... 3-11
CD70 Causing death by careless driving then failing to supply a specimen for analysis.......... 3-11
[u][b]Construction & Use Offences[/b][/u]
CU10 Using a vehicle with defective brakes.......... 3
CU20 Causing or likely to cause danger by reason of use of unsuitable vehicle or using a vehicle with parts or accessories (excluding brakes, steering or tyres) in a dangerous condition.......... 3
CU30 Using a vehicle with defective tyre(s).......... 3
CU40 Using a vehicle with defective steering.......... 3
CU50 Causing or likely to cause danger by reason of load or passengers.......... 3
[u][b]Reckless/Dangerous Driving[/b][/u]
DD40 Dangerous Driving.......... 3-11
DD60 Manslaughter or culpable homicide while driving a vehicle.......... 3-11
DD80 Causing death by dangerous driving.......... 3-11
[u][b]Drink or Drugs[/b][/u]
DR10 Driving or attempting to drive with alcohol level above limit.......... 3-11
DR20 Driving or attempting to drive while unfit through drink.......... 3-11
DR30 Driving or attempting to drive then failing to supply a specimen for analysis.......... 3-11
DR40 In charge of a vehicle while alcohol level above limit..........10
DR50 In charge of a vehicle while unfit through drink..........10
DR60 Failure to provide a specimen for analysis in circumstances other than driving or attempting to drive.......... 10
DR70 Failing to provide specimen for breath test..........4
DR80 Driving or attempting to drive when unfit through drugs.........3-11
DR90 In charge of a vehicle when unfit through drugs..........10
[u][b]Insurance Offences[/b][/u]
IN10 Using a vehicle uninsured against third party risks.......... 6-8
[u][b]Licence Offences[/b][/u]
LC20 Driving otherwise than in accordance with a licence.......... 3-6
LC30 Driving after making a false declaration about fitness when applying for a licence..........3-6
LC40 Driving a vehicle having failed to notify a disability.......... 3-6
LC50 Driving after a licence has been revoked or refused on medical grounds.......... 3-6
[u][b]Miscellaneous Offences[/b][/u]
MS10 Leaving a vehicle in a dangerous position.......... 3
MS20 Unlawful pillion riding.......... 3
MS30 Play street offences.......... 2
MS40 Driving with uncorrected defective eyesight or refusing to submit to a test.......... 3
MS50 Motor racing on the highway.......... 3-11
MS60 Offences not covered by other codes.......... As Appropriate
MS70 Driving with uncorrected defective eyesight.......... 3
MS80 Refusing to submit to an eyesight test.........3
MS90 Failure to give information as to identity of driver etc..... 3
[u][b]Motorway Offences[/b][/u]
MW10
Contravention of Special Roads Regulations (excluding speed limits)..........3
[u][b]Pedestrian Crossings[/b][/u]
PC10 Undefined Contravention of Pedestrian Crossing Regulations.......... 3
PC20 Contravention of Pedestrian Crossing Regulations with moving vehicle.......... 3
PC30 Contravention of Pedestrian Crossing Regulations with stationary vehicle..........3
[u][b]Speed Limits[/b][/u]
SP10 Exceeding goods vehicle speed limits.......... 3-6
SP20 Exceeding speed limit for type of vehicle (excluding goods or passenger vehicles).......... 3-6
SP30 Exceeding statutory speed limit on a public road.......... 3-6
SP40 Exceeding passenger vehicle speed limit.......... 3-6
SP50 Exceeding speed limit on a motorway.......... 3-6
SP60 Undefined speed limit offence.......... 3-6
[u][b]Traffic Direction and Signs[/b][/u]
TS10 Failing to comply with traffic light signals.......... 3
TS20 Failing to comply with double white lines.......... 3
TS30 Failing to comply with "Stop" sign.......... 3
TS40 Failing to comply with direction of a constable/warden.......... 3
TS50 Failing to comply with traffic sign (excluding - stop -signs, traffic lights or double white lines).......... 3
TS60 Failing to comply with a school crossing patrol sign.......... 3
TS70 Undefined failure to comply with a traffic direction sign.......... 3
[u][b]Special Code[/b][/u]
TT99
To signify a disqualification under totting-up procedure. If the total of penalty points reaches 12 or more within 3 years, the driver is liable to be disqualified..........
[u][b]Theft or Unauthorised Taking[/b][/u]
UT50 Aggravated taking of a vehicle.......... 3-11
