RS200_Altezza
February 5, 2005, 6:36 am
Hey guys
I have an Altezza RS200 with the 3sge engine and 6 spd tranny.....my check engine light comes on periodically, when it is on the car bogs down badly, sluggish performance, rapid fuel comsumption, rought jerky gear changes and whats not!
I had a diagnosis done and it gave me an O2 sensor reading. My question is...do you guys think it may just be a wire breakage on the sensor? If the sensor was totally bad it would not work at all I thought.
I await your feedback....
Cheers
tdiplc
February 5, 2005, 10:14 am
Could be either. Check the wiring continuity 1st, then the o2 signal.
RS200_Altezza
February 5, 2005, 10:23 am
thanks will try that....I had reset my computer a few days ago and it was fine for about 3 days or so but then it came back on again....I will check the wiring as you stated and then go from there...
thnx
hkaltezza
February 22, 2005, 3:42 pm
Hello, My car also have some problem...........May I know that IS300 the o2 sensor is same as RS200?? Checked the sensor also made by Denso..........Pls kindly help. Thanks!!
