legendswraith
March 18, 2005, 1:43 pm
right i have just got a induction kit for my 94 gs300 and i need to mod the mass airflow sensor fitting slightly from the look of the bottom of the sensor there is the main sensor part then further up there is a long plastic dowel, this dowel is what i am worried about i don't know if it is a location dowel or a sensor in its own right and i need to take this into consideration when i mod the bracket so if anyone knows anything about it any advice would be appreciated
Matthew_McNally
March 18, 2005, 2:09 pm
which kitdid you get mate?
legendswraith
March 18, 2005, 2:30 pm
got a bomz one off ebay chucking the filter in the bin though and getting a proper one even so with the price of the new filter it will be a hell of a saving
Mr Morse
March 18, 2005, 6:03 pm
Here's a pic of a K&N Typhoon on my IS300, if it helps....
legendswraith
March 18, 2005, 8:07 pm
thanks morse but its actually a piece of the Mas that goes into the airflow (maybe) it looks like a dowel to me but i reckon i better make sure anyhow i just whittled myself an adaptor out of stainless so with a touch of technical magic and alot of prc we will see if it works
If it does work out ok i will try to post a pattern for an adaptor on here if anyone else wants to take up the challenge lol
Mr Morse
March 18, 2005, 9:43 pm
[quote name='legendswraith' date='Mar 18 2005, 02:43 PM']right i have just got a induction kit for my 94 gs300 and i need to mod the mass airflow sensor fitting slightly from the look of the bottom of the sensor there is the main sensor part then further up there is a long plastic dowel, this dowel is what i am worried about i don't know if it is a location dowel or a sensor in its own right and i need to take this into consideration when i mod the bracket so if anyone knows anything about it any advice would be appreciated
[right][snapback]221166[/snapback][/right][/quote]
Wasn't exactly sure what you meant - thought it mught have been the rubber capped drain below the "K&N" logo on the pipe.
Anyway geezer, good luck - these induction kits have a positive effect on throttle response AND make a good noise
Mike
legendswraith
March 19, 2005, 4:09 pm
attacking this from another direction now going to incorporate the original mas and fitting into the induction kit
One day i will do this the easy way but i am having so much fun taking things to bits its like lego for adults
legendswraith
March 29, 2005, 11:07 pm
finally got the induction kit sorted just used the original kits induction pipe cut off the mk2 maf sensor mounting and got some silicon hose and fitted the maf sensor housing onto the induction pipe then nipped down to the machine shop and whittled an adaptor for the front of the maf sensor housing out of aero aluminium and voila a tailor made induction kit. Now as soon as i can find a good number for some t-bar clamps i will replace the jubilee clips and it will look the business
Rob
March 30, 2005, 9:01 am
ah ha thought u had something to do with aviation as u mentioned PRC - great stuff isnt it ! LOL
depending what fleet u have, i have a few PN's for clamps, will try dig them out of my box next week.
legendswraith
March 30, 2005, 9:12 am
[quote name='fluff34567' date='Mar 30 2005, 10:01 AM']ah ha thought u had something to do with aviation as u mentioned PRC - great stuff isnt it ! LOL
[right][snapback]224758[/snapback][/right][/quote]
yep certainly makes finding hard to find bits easier and it looks like you are hard at work when you are poring through a parts catalogue need to find a jet that has a few more transferrable parts though
Rob
March 30, 2005, 9:14 am
ECS pack clamps or ecs system ducting, thats the best bet i reckon.
legendswraith
March 30, 2005, 12:03 pm
[quote name='fluff34567' date='Mar 30 2005, 10:14 AM']ECS pack clamps or ecs system ducting, thats the best bet i reckon.
[right][snapback]224761[/snapback][/right][/quote]
yeah but its all orange and theyll get suspicious if i ask for another colour lol
Rob
March 30, 2005, 12:05 pm
nah i didnt mean use ecs ducting, meant clamps off the ducting, i have loads of clamps that are not the T-bat ones but ones that do use a threaded rod and have a 1/4 head ill get the Pn for u
legendswraith
March 30, 2005, 2:03 pm
[quote name='fluff34567' date='Mar 30 2005, 01:05 PM']nah i didnt mean use ecs ducting, meant clamps off the ducting, i have loads of clamps that are not the T-bat ones but ones that do use a threaded rod and have a 1/4 head ill get the Pn for u
[right][snapback]224844[/snapback][/right][/quote]
think i know what you mean similar to jubilees but more robust and less unsightly
Full Colour Version:
Mass Airflow Sensor
click here.
