Colin P
March 19, 2005, 7:14 pm
I bought a new battery and the leads from the car wont reach, I seem to remember someone saying you can get some kind of battery extension kit? is this true? I have searched but can't find any information.
I'm off to Halfords to have a look tomorrow.
Lexus dont exactly give you a lot of cable!
Thanks in advance..... back to the rugby
Colin P
March 20, 2005, 3:29 pm
42 views and no reply???
I bought some battery cables from halfords but don't have a clue how to join them together? I tried soldering them and the solder just kept dropping off! Now I think the iron needs a new tip.
someone help please! I'm pretty ****** off!
Rob
March 20, 2005, 3:59 pm
if the leads dont reach then the new battery is the wrong size, as for the solder unless u have a huge iron u wont get the cables hot enough for a proper join.
your option is to :
get a different proper size battery
find a cable joiner that uses bolts to clamp the cables together.
T7RY B
If it is a new battery. Then change it for the correct one( with fittings in the same position) that came off the car?
Colin P
March 20, 2005, 4:04 pm
its a deep cysle battery for car audio stuff so there isn't really another battery I can use. I thought it would be a case of adding some more copper wire to the original ones and that would be it but I have no idea what thickness the standard cable is or how to join the new and old cable together. Now I can't even drive the car!
I know other members have these batteries and I thought it would be a straight fit but the two positive wire wont reach.
Colin P
March 20, 2005, 4:07 pm
it's the exide 900 dc by the way
however I have the one labelled as a deta
[url="http://www.rthursby.co.uk/acatalog/deep_cycle.html"]http://www.rthursby.co.uk/acatalog/deep_cycle.html[/url]
Bob King
March 20, 2005, 5:59 pm
Colin , the Bosch battery i fitted the other month was the same , connections at the front ,not the back, the black lead had enough slack ,and the red lead i unclipped the cable on the bulkhead, and it then fitted.
Once fitted and checked for bonnet clearance , i cable tied the cable into its new position......job done
Colin P
March 20, 2005, 6:20 pm
yea cheers, I had unclipped it from teh back alread but it still just a bit too short. I have the wire so i'm just going to get a screw in connector and see how that goes. I temporarily connected the battery and for some reason the car started locking/unlocking itself when i opened and shut the door. Dunno what that's about?
rajhirani
March 21, 2005, 9:19 am
Hi Colin
i have the same battery and my mine fitted with no problems at all.
maybe you might have it the wrong way round?
Raj
Colin P
March 21, 2005, 2:31 pm
haha no, it was the right way around. Just extended the leads now and it's all working perfectly. I wish it would stop raining so I can put the amps in though!
Full Colour Version:
New Battery
click here.
