Full Version: Suspension Advise For 1990 Ls400
Lexus Owners Club > Lexus Models > LS 400 / Lexus LS430 / Lexus LS460 / Lexus 600h Club > Brakes & Suspension
keanlim
I live in Kuala Lumpur, Malaysia and own a 1990 Lexus LS400 with suspension problems. I am looking for a cost effective replacement for the following parts. Can anyone in the forum help?
Front Absorbers
Front Absorber Mountings
Front Upper Spring Insulator
Rear Absorbers
Rear Absorber Mountings
Rear Upper Spring Insulator
Rear Arm Assembly
Rear Strut Bush
Rear Suspension Arm Bush
Rear Upper Arm Assembly
Rear Knuckle
Rear Link Rod
Rear Lower Spring Insulator
Rear Stabilizer Bar Bush
Front Lower Arm Bush
Front Upper Arm Assembly
Front Strut Bar Bush
Front Stabilizer bar bush
Tie Rod End left
Tie Rod End Right
Steering Rack End (both sides)
I do not mind having non-factory parts as long as it is better than the OEM parts. Any advise will be greatly appreciated.
Rgds
Kean
jdmparts_guru
That's a lot of stuff!!!
Send me a pm with your phone no and email, perhaps i can arrange something
jamac
[quote name='jdmparts_guru' date='Apr 5 2005, 10:22 AM']That's a lot of stuff!!!
[right][snapback]227075[/snapback][/right][/quote]
I have a similar problem. I need to replace the rear carrier bush and the lower arm bush. I would like to find relacement bushes rather than replace both the carrier and arm. Is there something available ???
Nokia
Mr KeanLim
U GOT PM.
ROYT
JAMAC.......Check ldmautoparts USA [Ebay] , I got rear trailing arm and rear axle carrier bushes from them.
[ polyurethane]
I was told r/axle carrier bushes are not available from Lexus, but I have not tried to confirm it. :)
