Millatyme
September 23, 2002, 12:28 am
hey guys... ok when i recieved my car in August I was aware that the air hose coming from the air box was broken... Not knowing what caused it and that it just needed to be replaced I didnt think much of it only because the owner before me taped it up with electrical tape and it looked pretty secure...then after reading a copuple threads in here about motor mounts i realized that i need to replace my motor mounts-
1. b/c they are way over due and I can definitly feel it when I punch it or even put the car in reverse before i back out in the driveway in the morning .
2. b/c they are probably what broke that air hose in the first place.
So one of my questions is how much does a replacement air hose go for?
And another question is where are the motor mounts located so i cant look and see which if not all need to be replaced?
thanks a lot for your help and time!!!
Miletyme
Steven
September 23, 2002, 4:20 pm
This is easy... easy to install too
The air hose you can order from your dealer and should be less than $100.... maybe even less than $50
Youn can even install this yourself.... just be prepared to give the old one a good tug out.
The engine mount is at the top (see pic below) This is simply undo two bolts and replcace new mount. Mount costs is about $70 or less
Millatyme
September 23, 2002, 4:41 pm
:?::?:thanx a lot for the info, that is very reassuring that this wont cost me an arm and a leg!!! Is there anyway u could describe where to look for this front motor mount? b/c I have no idea where to look... I also own a 94 ES300 so would the mount be located in a different spot? thanx a lot for ur patience...im just a beginner:o:o
Steven
September 23, 2002, 11:13 pm
should be next to the Cam Shaft casing.... left hand side of the engine... reminds me of a metal dog bone
look at the pic and your sure not to miss it next time you see it
Millatyme
September 24, 2002, 12:28 am
I SEE THE LIGHT!!! thanx for pointing that out for me... and it definity needs to be replaced and looks very easy to do. So when i order this from a dealer what do i ask for, the front motor mount? The reason i say this is b/c i want to make sure they send me this part and not something that is in the "front" of the engine:D
where are the other motor mounts located? And how hard are those to replace?
click here.
