Full Version: How To Set Harrier Clock?
Lexus Owners Club > Lexus Models > Lexus Imports Clubs > Harrier Club
sdab57
I have just got a Harrier 3.0 with the TV/SAT NAV/etc can anyone tell me how to set the clock as I don't have a handbook.
TIA
Dom
T7RY B
The clock works via the Sat/Nav. Hence your Sat/Nav not being active your clock comes on at 09.00 every time you start the car.
sdab57
[quote name='T7RY B' date='Jun 21 2005, 07:57 AM']The clock works via the Sat/Nav. Hence your Sat/Nav  not being active your clock comes on at 09.00 every time you start the car.
[right][snapback]256086[/snapback][/right][/quote]
I don't think thats how ours works as I have taken the satnav disc out and the clock is running normally just on Japan time. Any ideas?
solos
I vade the same problem and I do not know how to set clock time on rx300 harrier. There is no clock butom but TV buttom. ALSO THE CAR WAS IMPORTED FROM JAPAN. Do you know how to set clock time, because some of them are written in japanice?
T7RY B
[quote name='sdab57' date='Jul 1 2005, 12:21 AM'][quote name='T7RY B' date='Jun 21 2005, 07:57 AM']The clock works via the Sat/Nav. Hence your Sat/Nav  not being active your clock comes on at 09.00 every time you start the car.
[right][snapback]259239[/snapback][/right]
[/quote]
Mine always comes on at 9.o'clock as I said,but if yours is on normal time but just out os sync.Then disconnect your battery and see what time comes up?
If for example it comes on at 8.O'clock then you will have to take the battery lead off at 5 to 8 then put it back at exactly 8 O'clock then it will stay in sync with your correct time.
But I am positive it is run through the Sat/Nav.
Full Colour Version: How To Set Harrier Clock?
