Full Version: Coolant Picture
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
bowker
Can someone post a picture of what the coolant looks like when it is full in the viewing window
Also can you seen the coolant when you open the cap onto of the radiator?
I have bent my rad at the bottom but it doesnt leak however could this have caused my washer bypass valve to leak for some reason as coolant is coming out when it feels like it and I am worried as I cant check the level as I cant see anything in the viewing window :(
The temp needle is fine but I would ratehr be safe than sorry
[quote name='bowker' date='Jun 27 2005, 01:36 PM']Can someone post a picture of what the coolant looks like when it is full in the viewing window
[right][snapback]258127[/snapback][/right][/quote]
car engine is cool, took rad cap off and i can see coolant :D what viewing window by the way ?
bowker
There is a little window at the back of the rad under the trunk for the air filter
crazylex
Should be able to see fluid level inside the white transparent part. Theres a max/min level marker - or may be hot/cold marker.
When car is cool open metal lid on rad you should be able to see fluid upto top.
You should not see fluid when opening the plastic filler cap.
bowker
I cant see any in the window!!!
The temp is always ok and I went Newcastle and back in a day 350miles
It does leak from the water by pass valve every now and then which I need to sort
The rad got pushed up at the bottom by 1 or 2 rows but has not shown signs of leakage
crazylex
sounds a bit blazay (spelling ??)
but fill it up and see what happens.
Just in case you are loosing it somewhere you dont want to let it go so low.
You need to establish if the level keeps going down.
Can you see any pink (assuming its the toyota fluid) dried residue anywhere ?
Full Colour Version: Coolant Picture
