QUOTE(rhosneigr @ Jul 22 2005, 05:00 PM)
The report on my front tyres after a 20K service read the same for both tyres
2mm outside 4mm centre 2mm inside. I check the tyres weekly and run at 2.4. Why do the edges wear more than the middle?
[snapback]265871[/snapback]
First 'Congratulations'
an IS without camber wear on the front is rare, The pressures are within reason a suggestion the ideal setting is unique to you and your car, adding an extra two psi would be a good move.
