Full Version: Please Help
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h > Engine & Transmission
phillls400
Hi there, this is myt first post, and i know nothing about my
L reg 1993 LS400.
here's my problem, the professional rip off merchants at my local lexus dealer want to charge me mega bucks for a couple of parts that need fixing. namely they are
a new alternator
and a new power steering pump
they want to charge me 450 pounds plus VAT just for the pump, surely that cant be right.
i've sourced some OEM parts from a USA distributor and the total for both parts comes to less than £350.
im a bit concerned though that the parts will be for a different version of the 1993 ls400
the part numbers i have are
alternator 27060-50080
power steering pump 44320-50020
i was also thinking about looking for some reconditioned parts.
can anyone confirm i've got the right numbers? or does anyone out there have any suggestions?
Thanks Muchly
Phill
chris vince
QUOTE(phillls400 @ Aug 1 2005, 02:48 PM)
L reg 1993  LS400.
a new alternator
Thanks Muchly
Phill
[snapback]268599[/snapback]
chris vince
L reg 1993  LS400.
a new alternator
Thanks Muchly
Phill
Phill,
There are plenty of pieces on power steering pumps on these pages do a search. Make sure it isn't the failure of the 5p 'O' ring on the base of the PS pump reservoir causing your leak before you shell out a fortune, I have repaired 2 cars with this fault it is not uncommon, and an easy fix.
Chris Vince
Leadfoot
When the pump blows it drops its fluid into the alternator and kills it. The Lexus Stealer is quoting new parts and thats the gauranteed way to go, although it does cost.
You may get hit by customs for parts sent from overseas, or you may be lucky. It can take some time for the bill to catch you though.
My 92 LS400 pump died on Sunday, been giving me trouble so am having the pump and rack reconditioned. I will try http://www.powersteeringservices.co.uk/startup.html
they only recon your own units. Should know how it turns out by the end of this week. Costing me £300 to have both parts pulled out and refitted, recon TBC, but was quoted over phone about £275, incl shipping (all excl VAT)
Good luck,
Leadfoot.
