Full Version: Is 200 Rear Spk Replacement
Lexus Owners Club > General Lexus Forums > Lexus Audio/Video/Electronics/Security
marcus gregory
I have just purchased a pair of Infinity 6 by 9 oval speakers to replace the factory fit version. I hav'nt got a clue how to take the old ones out ,as it appears that they have to be taken out from the top which involves taking the covers of first. I have spoken to my local Lexus dealer who says that the rear seats have to be removed ? This seems a bit excessive to me. Any ideas welcome.
brn7y
Matt will answer this he's done it.
Monster-Mat
ok its a big job but not hard,the seats do need removing..........here goes
1.remove seat base,pull up ends to reveal bolts
2.remove seat back,bolts at the bottom,lift up at the top(yank hard)
3.remove rear "C" pillar covers,just pull off
4.remove the rear deck cover,remember the wires are connected to the brake light
5.disconnect brake light wires
6.the rear speakers can now be removed,cable connections are underneath
7.when reconnecting the wires,dont use all 4 wires the speakers will sound crap,just use the mid or high spker wires
fitting is reverse of removal
*no responsability is taken for any work carried out by following instructions on the forums*
mat
brn7y
Matt and his disclaimers!!
"Always remember no responsiblity can be taken by me if you bugger up anything I explain how to do correctly" is what you should say.
:lol: :lol: :lol: :lol: :lol:
Monster-Mat
Hmmmmm
:D
oh by the way the speakers will not be a direct fit,the IS200 speakers sit in a cradle which is slightly larger than 6x9 :ph34r
[QUOTE]Matt and his disclaimers!!
[QUOTE]
marcus gregory
Wow, thanks for the quick respones to my query. Will the spks i have still fit in the original holes,or will I need spacers? I thought I read that the originals were 6 by 9's? I wish it would stop raining,so i can get cracking.
Monster-Mat
yes they will fit.......,you may need to drill some extra holes in the deck,bt this really depends on the speakers being fitted...............
marcus gregory
Thanks for the info,I'll get cracking Monday.
Monster-Mat
if you get any probs.....PM me
mat
Ibbydave
Hey, I'm new here - bought my is200 about two weeks ago!! Best car i've owned by FAR!!!! already done a few mods (tasteful, ofc) - took on the task of changing the 6x9s and found it to be very easy! if not a little fiddly! now have a pair of MDF mounted speaks sitting snug!
The lower half of the rear seat literally just pulled out of two clips at the front, and two at the back, very easy. The rear of the seat, 4 bolts that took no time to undo
Only problem I had was pulling the tray too far and snapping the brake light bulb housing, thought it had more give than it did, easy fix but be careful not to pull it out too far before you disconnect it!! also reaching the screws nearest the rear windows was tricky, putting a small piece of packing foam between the socket wrench and the window stopped the tint from being scratched.
Great mod, sounds good - and useful to know how everything fit together back there!
Thanks for the help =)
Full Colour Version: Is 200 Rear Spk Replacement
