Full Version: K&n Typhoon Fitted To A Gs300
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
eXOBeX
Fitted a K&N Typhoon to the Lexus this week. Sounds nice when you blip the throttle, but pulling away for the first time after turning the key feels REALLY sluggish, car takes a little while to perk up.
I've reset the ECU, made no difference. Any suggestions before I ditch the Typhoon and go back to the standard intake?
p.s. the Typhoon is for the IS300, I figured it would work in the GS as the engines are the same, only the mounting points and shape of the standard intake differ.
ColinBarber
Unless the internal diameter of the intake pipe where the maf sensor is location is the same as the stock intake then the fueling will not be correct. Maybe that is the problem. The GS and IS may share the same engine but is the intake the same? If not the the ECU is probably different as well.
eXOBeX
Hmmm... will have to check.
Incidentally, the drop-in filter for the GS300 is the same as that for the IS300, the [url="http://www.knfilters.com/search/applications.aspx?Prod=33-2170"]33-2170[/url].
AFM is the same on both (22204-22010 fits LOADS of different cars, from the Scion xA to the LS430).
eXOBeX
Depth of sensor hole (from top of screw holes): GS300 77mm, K&N 81mm
Internal diameter of pipe at sensor location: GS300 67mm, K&N 72mm
Would I be able to narrow the pipe at the sensor location using a 2.5mm thick layer of 1" wide PVC electrical tape, or is the air turbulence from this likely to cause issues?
Or should I just whack the whole thing back on eBay?
Jiberjaber
[quote name='eXOBeX' date='Aug 11 2005, 09:04 AM']Depth of sensor hole (from top of screw holes): GS300 77mm, K&N 81mm
[right][snapback]272318[/snapback][/right][/quote]
If your going to give up on it, let me know and I may take it off your hands :)
ColinBarber
Have you put back the standard intake? Did it improve things? If so I wouldn't mess around just sell it, unless you want to put it on a rolling road and get the fueling checked/corrected.
eXOBeX
[quote name='ColinBarber' date='Aug 11 2005, 08:42 PM']Have you put back the standard intake? Did it improve things? If so I wouldn't mess around just sell it, unless you want to put it on a rolling road and get the fueling checked/corrected.
[right][snapback]272624[/snapback][/right][/quote]
Will swap back tomorrow lunchtime.
eXOBeX
Swapped back to the stock unit this morning, car's happy again.
Full Colour Version: K&n Typhoon Fitted To A Gs300
