Full Version: Ngk And Denso Sparkplug Gb
Lexus Owners Club > Buyers and Sellers Corner > Group Buys > Group Buy Archive
Steve
This is a group buy for NGK and Denso performance spark plugs
Links to the group buys
6x NGK IRIDIUM Spark Plugs
http://lexus.group-buys.co.uk/view-group-buy.php?id=6
4X NGK IRIDIUM Spark Plugs
http://lexus.group-buys.co.uk/view-group-buy.php?id=5
6x Denso IRIDIUM Spark Plugs
http://lexus.group-buys.co.uk/view-group-buy.php?id=4
4x Denso IRIDIUM Spark Plugs
http://lexus.group-buys.co.uk/view-group-buy.php?id=3
New Users to the Group Buy system
Simply register your details and then click the "join this Group Buy" link on the Group buy page.
PLEASE READ *** IMPORTANT***
Payment Must be Made directly after GB has closed (We will notify you of this). Failiure to pay whithin 48 hours will result in your name being removed and GB being delayed and keeping other members waiting. Fast payment is important in group buys. You bid is to buy.
aido
Steve, do you know the model number for the Denso plugs please mate?
Steve
I will get in contact with the denso distributor on monday and get these.. i should have got the numbers and posted them here.
Matthew_McNally
wow - they seem really good prices.
whats OEM on a GS430? Is it the Denso ones?
Steve
not 100% sure mate.. US use both as far as I am aware
whiteman
Which is best for the IS and wot is the difference between the denso ones and NGK ones? ( apart from the price)
legendswraith
QUOTE(whiteman @ Aug 13 2005, 08:32 PM)
[snapback]273149[/snapback]
I just put some denso iridiums into my gs (IK16's) and can heartily recommend them alot smoother running with these in will warn those with the 2jz engine they are a bit of a swine to change though.
Steve
QUOTE(whiteman @ Aug 13 2005, 07:32 PM)
just brand difference... some car companies prefer a certain brand over the other
Denso was the first manufacturer that came out with the Iridium design, and is regarded as the leading company. Many aftermarket specialists such as HKS are using Denso for their high performance plugs
NGK has been playing catch up with Denso, and also have the Iridium technology, but in order to conquer market share, their prices are lower than Denso.
Some people think that Denso are better than NGK .
Steve
Denso IK16, IK18, IK20, IK22, IK27 are all available at same price
Mr Morse
The Denso Iridium plug types for the IS are as follows:
IK16: IS300 (these are high performance plugs and should be changed @ 30K)
IK20: normally aspirated IS200
IK22: Supercharged or Turbo'd IS200 (these are high performance plugs and should be changed @ 30K)
jdmparts_guru
hmmm...
IK16 plugs are less aggressive, but will likely last longer.
I am using IK20 plugs on my GS300, but want to try the IK22 next time.
Most Altezza drivers i know use IK22.
jdmparts_guru
http://www.iridiumpower.com/faq.php
Q. What makes Iridium better?
A. Until recently, platinum was considered the best material to use on the top of an electrode because of its durability. However, Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum. Put that into a harsh environment such as an engine piston chamber, and you have a spark plug that can resist wear much better than platinum. Additionally, the DENSO Iridium Power alloy is so durable; it allowed our engineers to produce the world’s smallest center electrode (.4mm) which reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion.
Q. How long will Iridium Last?
A. Iridium use represents the most significant technological advance in automotive spark plug manufacturing, since platinum was introduced in the early eighties. As vehicle manufacturers produce increasingly complex and efficient automobiles, there is a greater need for long-life plugs that can tolerate leaner fuel mixtures and improved combustion processes. DENSO has responded to this need by developing its Iridium alloy, originally for OE applications. For example, many newer Lexus’ and Toyota models carry an ultra long-life Iridium plug variation (.7mm with platinum tipped ground) that is capable of up to 120,000 miles of service. DENSO Iridium Power plugs, with their .4mm center electrode, have been developed for performance applications. Because gradual wear will “round-off” firing points over time, the concentrated firing power and voltage requirement benefits will be reduced. For this reason, DENSO advises replacement after 30,000 miles.
Q. What kind of performance will I get from this plug?
A. Generally, you do not purchase spark plugs for performance enhancement. While DENSO Iridium Power spark plugs have contributed to numerous accomplishments through dyno-testing and actual use, their true benefit lies in their efficiency, durability, and improved firing power. Serious tuners modify their vehicles by increasing boost through turbo-chargers, super-chargers, and Nitrous. They are also known to add high-energy ignition systems, tinker with timing, adjust fuel mixture ratios, and increase horsepower through other means. Putting these kinds of demands on their engine increases the need for an efficient, durable spark plug that can handle these kind of harsh environments. That’s where DENSO Iridium Power can make a major difference.
ColinBarber
QUOTE(Steve @ Aug 14 2005, 04:47 PM)
[snapback]273355[/snapback]
Denso where once Toyota and they still own around 20% of the company. Denso IK range of performance plugs are probably the best you can get. HKS and TRD rebadge them.
aido
Sorry to take this off topic slightly guys but what are the IK27's for?
And which Denso plugs are the equivalent of the HKS plugs? I was under the impression that the HKS Racing plugs were the same as the IK20's which was why I originally fitted IK20's when the SC was fitted?
Thanks in advance, that's a superb price Steve, can I get two sets please mate?
ColinBarber
IK27 - a couple of Honda bikes:
http://www.densoproducts.com/resultsSearch...PartNumber=IK27
Steve
QUOTE(aido @ Aug 16 2005, 02:30 PM)
[snapback]273876[/snapback]
Aido
Please register on the Gb system
Then goto one of the links , login and then on the page click the "Join GB link"
Once you have done this your name will be reserved.
cheers
jdmparts_guru
IK27 are also widely used for very high revving cars ... Honda Civics, ... laugh.gif
whiteman
biggrin.gif I am interested in this group buy but I am off on my hols on saturday so not sure if I should join has there is no means of payment so therefore I could be removed. Is it ok to register? Also having problem with my ISP.
Steve can you let me know how long it will be on for or is it till they are all gone?
gsportcars
Does anyone know what the deal is with the group buy on these???
I have joined the group buy early last week for the 6 denso plugs but I need the plugs asap. I have tried to contact Steve who is organising the group buy but I don't know if he has got the PM's yet as I have had no reply! crying.gif
I need to know if there is a time limit to how long this Gb will last and if it is too long for me then can I get my name taken off the list for the group buy as I will have to get the plugs elsewhere! blush.gif
help on this would be much appreciated from Steve or someone who knows more about this!
Thanks.
SHAHZ
I think the group buy will close when a certain number has been reached unsure.gif
gsportcars
I know that the number has to be reached but what if it takes weeks for it to be reached or if it is never reached!!!
I need the plugs this week and cannot keep the car off the road just to wait on plugs!!
The problem is that I know there is some sort of commitment issue when you join the group buy and I don't want to just leave the group buy unless I have to!!
I need to get some answers for this please from anyone that knows asap or I will have to get the plugs myself!!
Steve
gsportcars and I are in Pm conversation in case anyone thinks i am ignoring him LOL
I can get more of these than the GB is listed.. so no need to worry
but those who want a set should register and slap there name on a set.. then let me know the code you want.
liam
guys the company i work for supply both these company and all i can say is that denso quality standards are far superior than ngk.
Thats me own expierance
Ellz
QUOTE(liam @ Feb 24 2006, 01:25 AM) [snapback]333058[/snapback]
Can i still get some of these ?
lee_iceman
QUOTE(Ellz @ Apr 9 2006, 11:20 AM) [snapback]345470[/snapback]
I tried, signed up over 2 months ago, got some from ebayer in US, £38 delivered, 6 Denso IK22
Ellz
QUOTE(lee_iceman @ Apr 9 2006, 05:35 PM) [snapback]345564[/snapback]
Yep got mine off ebay IK20 tho, your a S/C bugga tho msn-wink.gif
