One of the things that makes me what i am is if i dont understand why 'dont' let it go!... So when i was setting the geometry on the IS 200/ 300 in volume every now and then i had a complaint....one in ten'ish had steering wheel offline to the right.
The final setting position of the steering wheel is only cosmetic but important for the overall result, at first i thought it was my eye, so i then asked the customer to set the position, still every now and then wheel off to the right.
Although my system Auto calibrates i then had Supertracker out to test the program and it passed no problem.
I pulled the reports to see if there was a common adjustment area 'angle' recovery that could explain why..... no luck, albeit one adjustment or fithteen there is no match to explain why.
Of all the fine tunes done so far the tyre wear issue that smothers the IS has gone so it would seem the then new WIM set-up is not to blame, i have been told that 'body noise' on some cars also has gone so it would seem the parallelograms also are at rest.
What has evolved is that geometrically there is three settings for the 200/300
GB
Europe
Asia
excluding index mark 99 and sport models
Of all the cars set few seemed to come back for the fine tune, this initaly worrid me so i made contact to find out why, seemingly the reason is distance, travel 400 miles have the geo done if now all is well then people are reluctent to travel back for the fine tune, this i can understand.....
So to my point if you have had a geometry done with me and the steering wheel ended up off line can you please pm me your index so that i can research the problem further.
What reads weird is that appart from the odd Micra the IS is the only car i have this issue with...... and one SC430!!! but i think that was my fault ( human )
As you can read this is not a good advert for me but i need to know why this cosmetic steering wheel position happens, and stop it!!!!!!
