Full Version: Low Power After 3000rpm
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h > Engine & Transmission
swordfish
had low power and missing on acceleration: have replaced:
timing belt, idler brg,tensioner,
plugs
leads
distributor rotors
caps
w.pump
accesory drive belt and pulleys,
still chasing low power on acceleration after about 3-4000rpm.
full throttle gives acceleration to 3-4000rpm, then it labours and wont go over 5000 till u bak off and then it changes up and accelerates till the same again occurs.
On scanning, no codes appear.
any ideas guys???/
chips229
Hi and Welcome to the LOC.
Maybe have a look at the fuel filter sounds like its not getting enough fuel,also check the air filter.
swordfish
changed fuel filter and air filter is ok.
chips229
Maybe try posting this topic on the US forum they might be able to help you,sorry dont know what else it could be.
http://us.lexusownersclub.com/forums/
Let us know if you find a fix.
Cheers chips.
star a
QUOTE(swordfish @ Sep 27 2005, 11:18 AM)
plugs
leads
distributor rotors
caps
w.pump
any ideas guys???/
[snapback]288542[/snapback]
throttle position sensor or dirty throttle body or
, poss ECU probs.
