Can you try this please pal (it shopuld of been \recycler - told you it was a long time since I used a pc
[url="http://symantec.atgnow.com/consumer/resultDisplay.do?gotoLink=3064&docType=1000&contextId=3864%3A3064.3171&clusterName=ConsumerCluster&contentId=fb0478c7-6988-436f-bf9d-4e56cb4dc1c5&responseId=ca5591d14505ac90%3A1b1fbf4%3A106f6b3b7fa%3A614a&groupId=1&answerGroup=3&score=900&page=http%3A%2F%2Fservice1.symantec.com%2Fsupport%2Fnsw.nsf%2Fpfdocs%2F19979410721&result=2&excerpt=The+UnErase+Wizard+displays+all+files+in+both+the+Norton+Protected+Recycle+Bin+and+the+Windows+Recycle+Bin.&resultType=5000#"]http://symantec.atgnow.com/consumer/result...esultType=5000#[/url]
[quote]ou want to free up more disk space on the hard drive by emptying the Norton Protected Recycle Bin.
Solution:
Norton Utilities automatically monitors your drive's free disk space to ensure that the Norton Protected Recycle Bin always leaves room on the drive for normal activities. If the amount of free disk space decreases, the size of the Norton Protected Recycle Bin will also decrease. Additionally, the Norton Protected Recycle Bin purges any files that have been in it over seven days. With these defaults, you may find that you do not need to empty the bin.
To empty the Norton Protected Recycle Bin
1. Right-click the Norton Protected Recycle Bin icon, and then click Empty Norton Protected Files.
2. Follow the prompts.
To change how often files are purged
1. Right-click the Norton Protected Recycle Bin icon, and then click Properties.
2. On the Norton Protection tab, select the drive from the drop-down list.
3. Check Purge Protected Files After.
4. Change the figure to a new number of days.
Manually empty the Norton Protected Recycle Bin in Windows XP/2000
If the contents in the Norton Protected Recycle Bin are not completely deleted, follow these steps to manually the remaining files.
To manually empty the Norton Protected Recycle Bin in Windows XP/2000
1. Restart the computer in Safe Mode. For information on how to start the computer in Safe Mode, read the document Starting your computer in Safe mode.
2. On the Windows Task Bar, click Start > Run.
3. In the dialog box, type command.
4. Click OK.
5. At the DOS prompt, type the following commands and then press the Enter key after each line.
C:
CD\
CD RECYCLER\NPROTECT
DEL *.*
CD ..
RD NPROTECT
6. Repeat step 5 for each drive on the computer.
7. When you are done, type exit, and then press the Enter key.
8. Restart the computer. The NPROTECT folder(s) will be recreated upon reboot.
Checking the amount of free disk space
In Windows 98, Norton Utilities hides the space used by the Norton Protected Recycle Bin. For example, if Explorer indicates the drive has 120 MB of free disk space, and the Norton Protected Recycle Bin is using 12 MB, the actual free disk space is 120 less 12, or 108 MB.
Norton Protection will not use up your free disk space. It monitors computer activity to see when you are writing to the drive, and decreases the size of the Norton Protected Recycle Bin so that you will always have free space on the drive. Under normal activity, you do not need to purge the bins yourself, since they are purged automatically.
If you anticipate that your free disk space is about to become unusually low and you want to ensure that you have sufficient free space for saving new files or installing programs, you can purge the bins just before saving or installing.
Note: Double-clicking the Norton Protected Recycle Bin icon opens the UnErase Wizard, a program which can recover files that have been deleted. The UnErase Wizard displays all files in both the Norton Protected Recycle Bin and the Windows Recycle Bin. In Windows 95 and Windows 98, it may also display deleted files that are no longer in either of the bins. Although it may appear that these files are taking up space on the hard drive, the files in the bins will be purged as needed, and any files not in the bins have already been deleted.
In Windows 98, once you empty both the Norton Protected Recycle Bin and the Windows Recycle Bin, none of the files displayed in UnErase Wizard are taking up space on the hard drive. These are fragments of files which have not yet been overwritten by the operating system, but which have been marked as deleted.
If you cannot get into Windows 98, but you still need to delete the Norton Protected Files, perform the following procedure.
To empty the Norton Protected Recycle Bin when you cannot boot into Windows
1. Click Start, then click Shut Down.
2. In the Shut Down Windows dialog box, click Restart, then click Yes.
Windows will shut down and the computer will restart. As the computer restarts, press and hold down the Ctrl key until the Windows 98 Startup Menu appears.
3. Select Command Prompt only to start Windows to a MS-DOS command prompt
4. Delete the NPROTECT directory by typing the following commands (press Enter after each command):
cd recycled
deltree nprotect
5. When the DELTREE command asks for confirmation, type Y and press Enter.
6. Repeat steps 5 and 6 on any other hard drives you have.
7. Restart the computer, and allow it to boot into Windows normally.[/quote]
Few different options in there mate
