aido
October 16, 2005, 3:03 am
my toilet has started flushing itself every hour or so - any ideas please?
think Rob sorted out Kae's which had the same problem - what was that about fella?
it's oneof those bogs with two button, a short flush and a man flush - just seems to be running water all the time and my bill will be massive
thanks in advance
johnboy
October 16, 2005, 7:56 am
think you got a problem with your stop ***** !
MacRS200
October 16, 2005, 8:19 am
Just natures way of repaying you for terrorising the good people of Nottingham
Seriously I would say problem with the ball ***** not sealing.
Mr Morse
October 16, 2005, 9:07 am
I'll pop over this avvo mate and take a look
aido
October 16, 2005, 10:01 am
Cheers buddy, guess it means I'd better clean up, it's like a warzone here
Thanks for the replies fellas, Rob did something at Kate's house when he stayed there to fix the same problem, think the stuff they used in these houses is crap
Rob
October 16, 2005, 10:55 am
push one of the buttons down then pull out the other button with ur finger, do the same with the other button, loosen the black plastic screw. remove the chrome bit then lift off the tank.
now if water is running al the time, lift the black plastic float up a little - does it stop running??
if so .............
the black plastic float has a steel rod going to a steel metal clip, squeeze the clip a bit and then at the same time slide the rod thru it a little, so it pushes the float DOWN a bit.
put the tank top together.
that should stop the water running, but dont tighten the screw too much or it will push the buttons down slightly and the water will start to leak again.
if when u lift the float up the water doesnt stop then the rubber washer has gone and u need a new one.
Geoffers
October 16, 2005, 10:59 am
aido
October 16, 2005, 11:03 am
Cheers Rob, will take a gander in a bit, as Geoff has guessed it's a little smelly in there right now
Ahmet
October 16, 2005, 11:46 am
My, was the "7" in the topic title a typo ?
aido
October 16, 2005, 12:08 pm
No fella, I have 7 bogs in my house
Yeah to be fair I was that away with the fairies that I couldn't hardly see what I was putting, miracle it made sense at all
waddy
October 17, 2005, 1:49 pm
When did it start doing that mate? I didn't think my tuddie was that big on friday morning.
More of a brown trout than a dead otter. - It wasn't even snapping at me - can't be my fault !!
It's all that stella and cheesy chips fella !!
