NE 1 lower the suspension more than 40mm?
'kg/mm' (japanese make)suspension maker sell lower springs for Altezza: lower on front 50mm & rear 45mm.
if so do u change shocks as well? i was told is advisable use shorten shocks if lower than 40mm
simonskippy
November 26, 2002, 8:13 am
If your going to drop it and change the shocks why not just go straight for coilovers? You can alter the ride height and damper settings at your leisure!
