chips229
February 7, 2006, 8:27 pm
POWERSTEERING OIL CHANGE
(PS= Powersteering)
Like you say the fluid should be Red in colour....The way ive changed PS fluid on cars is to jack the car up,have a oil drain catch tray,undo one of the PS pipes that come from the PS pump and drain it out or a pipe the goes to the steering ram....let all the fluid out,put the pipe back on and tighten up......Now top up the PS reservoir where the oil level check is when you take the top off...
Refill with new clean fluid until on MAX level...
Start the engine up and turn the steering to max left and right 2 or 3 times...from lock to lock.....that will get rid of any Air locks in the system....Now recheck the PS reservoir for the PS oil level and top up if you have to....
BRAKE FLUID CHANGE
The higher dot number should mean the fluid will not boil so quick..still boil but at a higher temp.
Same sort of idea as the PS fluid change,catch pan etc....id use a piece of plastic pipe the same sort of size as the brake bleed nipple and put the pipe on the nipple so when you bleed/pump the brake fluid oil it will go in your catch tray rather than on the tyre,
the brake fluid can/will damage the rubber of the tyre and make it dangerous..
I think from memory you should bleed the furthest wheel from the master cylinder first then in turn to the closest...
Take note of the colour of the old fluid as it pumps out and when you see clear fluid,that should be the new fresh fluid...Just bleed/pump out one wheel at a time in order as above...
You will need to Keep a Very close EYE on the Mastercylinder level or you will be pulling air into the system rather than fluid
(been there done that
If you find after fully bleeding with new brake fluid that the Brake pedal is soft...Lock/Jam a stick or something so the brake pedal is down putting pressure in the system....leave like that overnight and that should get any air out of the system...you should find the stick will be lying on the floor in the morning as it loses pressure overnight....
Hope thats of some help Fella....
Good Luck
Chips..
