Hows it going lads.
Thanks to all of you who acknowledged my plight for 18" alloys.
Had an interesting day with e-mails from the Lexus "should know" people.
I e-mailed both "Lexus Ireland" and "Lexus UK" for information on the availability of those elusive 18" wheels. Here are the replys I got from both of them
Please read and let me know your thoughts.
Matty
Lexus Ireland:
Hi Matt,
Unfortunately 18" rims are not available as an accessory on the entry level IS 250. However they are available on the Sport grade which is specifically set up to accommodate them. The reason for this is that changing the diameter of the wheel by two inches significantly effects the gear ratio, safety system inputs ( such as traction control and VSC) and speed readings.
However, there is an accessory wheel available ( which does effect these systems) for the entry level - a 10 spoke 17" alloy. Your dealer will be able to provide you with prices and availability of these wheels.
If you have any further questions please do not hesitate to ask
Lexus Uk:
Good day to you too, I hope you had a pleasant weekend.
This is what I can update you on at the moment.
If you were to purchase a Base model IS 250(with 16” alloys), you can
purchase 18” alloys and fit them later. I think whoever told you that the
Base model could not accommodate 18” alloys, meant they are not part of
the purchase package for the base model IS.
And which ever design you choose they would certainly fit all models,
however please be aware, that a larger wheel would effect your MPG reading.
If I can be of any further assistance please do not hesitate to contact me.
