Full Version: Repairing Plastic Bumpers
Lexus Owners Club > General Lexus Forums > Lexus Work Shop (Submit your Tip!)
gds
help, has anyone repaired cracks in is200 plastic bumpers successfully using diy materials from halfords.
they have a £30 kit which sounds ok but not much in the box for that amount.
creatinelex
ive seen them kits , look ok but prob better getting work done at a paint shop anyway , if its cracked it must need painted i would think. smile.gif
gds
QUOTE(creatinelex @ Mar 19 2006, 09:11 PM) [snapback]339856[/snapback]
great tip for workshop "go to your nearest bodyshop" don`t forget your chequebook. sleepy.gif sleepy.gif
Bazza
whatever it repairs it with must be flexible, like the bumper itself or its just going to crack again
TheDon
the only way to repair a good onld crack in plastic propperly is by "plastic welding" its pretty much just a hot air gun with a nozzle and a stick of ABS plastic. you heat the area then push in the new plastic rod and it fuses it all back together.
gds
QUOTE(TheDon @ Mar 21 2006, 10:01 AM) [snapback]340207[/snapback]
many thanks for your practical tip, how to weld the plastic.
as a result i sourced my local abs plastic rod, they said annother way to provide the heat for weldind is
to use an electric soldering iron, first spot welding the split to hold it together, then creating a "v" which then fill with molten abs. for a very strong repair this can be done on both sides with a larger "v" on the non show side.gds
Mattie
QUOTE(gds @ Mar 22 2006, 11:45 PM) [snapback]340755[/snapback]
Have a look at these mate. Spot on bits of kit
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...E:IT&ih=012
