dlayen
March 19, 2006, 7:01 pm
i have win 2000 pro on my pc and have tried to upgrade to xp pro because too many programs now will only run under xp.
but after downloading the recent xp installation software i find an upgrade is not possible and the only way to continue is to either partition drive and have another operating system on pc or format drive and start again so i choose to cancel.
i will move all files i want and install at a later date ..
but every time i turn pc on now it goes into xp setup and i have to select to go into win 200 o/s
how can i stop this happening?
sjf
March 19, 2006, 7:59 pm
[quote name='dlayen' post='339821' date='Mar 19 2006, 07:01 PM']i have win 2000 pro on my pc and have tried to upgrade to xp pro because too many programs now will only run under xp.
how can i stop this happening?[/quote]
Hi mate,
to be honest chooseing to cancel should have removed any of the Xp install......the only thing i can suggest is that once you enter win2000, you need to right click on my computer, select advanced and from that tab you will see the option called "start up and recovery"...its from here you can select what operating system will start at the boot process....
steve
crewe
March 19, 2006, 9:10 pm
Start Menu
Run
Type msconfig in the box
click on BOOT.INI Tab
click Check all Boot Paths
Delete XP
Hope this helps
dlayen
March 20, 2006, 7:31 pm
thanks for suggestions
i re-ran win2000 setup and all is well again now
click here.
