Full Version: Caliper Clearance On E-racers?
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
SunnySingh
Hey there dudes, am about to order me rims on Monday. Their stats say 18x7.5, 5x114.3 with an offset of 45 with Hankook Kingstars on em @ 225/40/18.
http://affilate.potn.com/images/konig/imkonigeracerblack.jpg
Has anyone got these on a IS? Do you guys think there might be a caliper clearance problem?
A geezer @ motorworld offered me Eibachs with a 40mm drop for £190 incl VAT. Can you get em with a 40mm drop? and will these 18's rub on em?
Any recommendations for a good garage to fit my Eibachs in the Midlands? (Near Cov, Brum etc..?) Bare Questions but all help is much appreciated. Cheers
Rob's Lexx
they should fit but may stick out a little.......i think blush.gif biggrin.gif
TheDon
the fit should be fine, would only stick out if it was a 35 offset.
i have a 42 offset and they are sweet as a nut
Rob's Lexx
QUOTE(TheDon @ May 6 2006, 07:18 PM) [snapback]351556[/snapback]
would it not make a difference that the rim is 7.5j opposed to 7????
Mr Morse
QUOTE(SunnySingh @ May 6 2006, 05:39 PM) [snapback]351547[/snapback]
Worth spending a bit more money on some decent rubber
Eibach's give a -30mm drop
If you don't mind travelling a bit further, try UPAuto in Cotgrave, south of Nottm
SunnySingh
Thanx alot Mr Morse for the advice. I've been quoted at another place £96 to have the springs fitting and £167 for the fitting and geo alignment together. You think thats a good price?
Mr Morse
£96 is a good price for the springs fitted but a correct 4-wheel alighment shouldn't be more than £40 unless you need some major adjustments.
