QUOTE(Steve ( West Mids ) @ May 31 2006, 10:13 PM) [snapback]356844[/snapback]
Is there no sump plug then on an Ls400? If there is I can't see why you would want a pump to suck it out, as these don't completely clear the sump.
Hi Steve
This is a bit complicated for you I think,The transmission oil is the main object of this excersise and if you check with the Lexus workshops thats the way they extract the transmission oil, but charge £70 per hour minimum for the service. So when the time come to change your t-oil you pay through the nose and us smart guys will use our pumps.
Regards Ambermarine
