Full Version: Help, Where's The Fuse/fuses ?
Lexus Owners Club > Lexus Models > Lexus Imports > Celsior
Ian10
driving to work today,when the radio stopped playing (the tape deck actually cos the radio's cack,import )no power to it,or to the changer in the boot,cant see anything on the rear of the radio headunit and unfortunately the manuals in haaaaaaaa soooooooooo lingo,so dont know which fuse to check or even if i'm looking in the right fuse box ? ( under the dash,below the bonnet pull ?) any help would be appreciated. Ian.
ps,it does help if i say what model it is, 1991 celsior but hoping the fuses will be the same !!
AU-LS400
Im not exactly sure, but there are two fuses for the stereo system.
Under the dash, three rows of five fuses, check the second from left, top row, number 2, should be 7.5amp.
Then in the engine bay, between the battery and coolant bottle, remove the cover and check the top left one, 20amp. number 1. Its the left one closest to the coolant bottle if you are facing the rear of the car.
