Hopefully one of you most knowledgeable folks can help me.
I own a 2001 GS430 Sport (basically one of a limited number of GS430 SE's with the sport styling kit). The car came fitted with 4 x Dunlop SP Sport 9000 245/40/ZR18. The tyres all have good tread and are relatively new but I've noted that the offside rear tyre has two puncture repairs.
Anyway I have handling problems when the road is uneven or rough - unfortunately this is the case with a lot of the roads in my area. Basically the steering twitches like a bucking bronco, and needs constant minor adjustment. If you come to a stop on a sloping road the steering turns gradually in the direction of the slope. The car handles quite well on flat roads and there is no steering "pull" when braking except of course if the road happens to be uneven at the time
I did take the car in to my Lexus main dealer, and they checked the suspension and shocks (all OK - phew!) and did a 4 wheel alignment (over £100 quid - ouch!). Though the geometry was slightly out, the alignment has has not cured the problem
Now I understand from reading the board and Googling that the symptoms I've described are the classic symptoms of tramlining, and tyre pressures could be the problem. The tyres on my GS430 are all set to 32 psi. The owner manual has a printed sticker in the tyre pressures section which states a recommended pressure of 32 psi front & rear for up to 4 people for speeds of up to 100 mph.
Now I notice from the knowlegebase that the recommended GS300 pressures for 245/40/ZR18 tyres are 35 psi front /32 psi rear for up to 4 people for speeds up to 100 mph.
Before I try these pressures, could any one advise whether they are running 245/40/ZR18 tyres on their GS? If so I'd appreciate if you let me know what pressures you are running at and whether you have any tramlining issues. Is it worth having the repaired tyre replaced?
Any help/advice much appreciated.
On the bright side the tramlining is keeping me honest. About a month back I was treading cautiously along an uneven stretch of the A30 (dug up by the cable TV installers), and I came upon a speed trap around a corner. If I didn't have tramlining issues I possibly may have been issued my first NIP ever! I guess every cloud has a silver lining
