Ok, sorry if this has been posted before, but i've just spent 20 minutes playing with the search function and not finding anything on them...
Anyway, the problem I have is I've recently taken my caliper off on the drivers side, and taken the caliper bracket off to clean it up and regrease the sliding pins. Now I'm not sure if anyone has noticed, but one of the pins on each brake round the car has a little rubber o-ring on it, it sits in a recess. Ok, I thought, be easy to put it back, however, when you try to slide the pin back in with the rubber o-ring on it, it just slides up the pin leaving the pin loose in the caliper bracket. I've tried and tried to get it back in, even applying a little bit of grease to the rubber o-ring to help it slide in, but no such luck.
So in the end I left it out. however since then I've had a clunk occur on the front brakes, presumably my drivers side, but only when you've gone backwards and applied the brakes (say in a car park) then driven forwards and had to apply the brakes fairly sharply. Suffice to say it sounds like the wheel is gonna fall off or the suspension is collapsing.
Does anyone know how to get these o-rings back in? I know they are fairly important since I now have a knock which I didn't before, and I suspect my dad's GS430 might be missing these little o-rings aswell, as that clunks like mad.
Paul
