darkan9el
October 28, 2006, 10:04 pm
[quote name='maneesh' post='391021' date='Oct 26 2006, 09:55 AM'][quote name='chips229' post='390974' date='Oct 25 2006, 08:46 PM']
On my mk1 Aristo after the keys have been removed the windows still work,even with the door open.But as soon as you shut the drivers door the feature cancels.
Hope thats of some help.[/quote]
I suspect that may be specific to mk1 JDM Aristos?
[quote name='P4UL T' post='390831' date='Oct 24 2006, 09:33 PM']Hi,
EDIT : I have just seen that your car is a 97, dunno if it is a mk1 or 2. The info I have put below applies to the mk2, not sure about the mk1
The leccy windows on the GS will still work for about 45 seconds after the ignition is switched off as long as none of the doors have not been opened.
Also you can remotly close the windows from outside the car by holding down the lock button until all the windows and roof have closed.
Finally, all four windows in the GS should be auto
HTH
Paul[/quote]
True for the mk2, but i believe he has a mk1, so it's only the drivers window that is auto.
I suspect that these features that he's after came out with the mk2, and I don't know of anyone that has altered a mk1 to have those features.
[/quote]
Yes it would seem I have a MK1 Gs300, as only the driver door is auto
looks like i'll have to develop tolerance... bugger!
