HI
while under the bonnet today I checked over the throttle cables and they all seem very slack
Correct me of I am worng here
there are 2 throttle cables one direct and one from a box of tricks on the front OS
there is a kick down cable on the bottom
How should these be adjusted as there seems loads of free play
also the alen screw with the 8mm nut on it / is that a tick over adjustment ?? as I seem to remember from another post I read that the tickover was set electronically
Should this be adjusted at all ?
