Full Version: New Disc Brakes?
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
darkan9el
Hi all, I have noticed the steering wheel shakes when braking from approx 60mph, I think I need new discs, so, where's the best place to get them? don't want to spend too much, but would like reasonable quality.
Also are they easy to fit and are there any instruction to do so?
Best regards Lee
webbbr
Are you sure that they are the brakes?
They are very easy to change.
I did mine a week ago.
Once the wheel is off, it is just 4 bolts.
Once the caliper is off, the disc just slides off. If they have been on there a while it may need a bit of persuasion.
darkan9el
[quote name='webbbr' post='392434' date='Nov 2 2006, 08:59 AM']Are you sure that they are the brakes?
Once the caliper is off, the disc just slides off. If they have been on there a while it may need a bit of persuasion.[/quote]
hi webbbr, yeah pretty sure, it only happens when braking and the discs have a small ridge on the outer edge which would suggest they have worn down to the minimum width and as a consequence are beginning to warp.
randyreindeer
Make sure you don't have a sticky Piston or Two. It can cause the same symptons.
webbbr
I got mine from these guys....
www.bypartsbuy.co.uk
Standard discs are here.... Price - £24.95 + vat
[url="https://sslrelay.com/buypartsby.co.uk/discs_details.php?recordID=4009"]https://sslrelay.com/buypartsby.co.uk/discs...p?recordID=4009[/url]
these are the one's i went for in the end..... Price - £111.88 + vat
[url="https://sslrelay.com/buypartsby.co.uk/discsdetails.php?recordID=2306"]https://sslrelay.com/buypartsby.co.uk/discs...p?recordID=2306[/url]
Look great on the car....
darkan9el
[quote name='webbbr' post='392617' date='Nov 2 2006, 07:57 PM']I got mine from these guys....
Look great on the car....[/quote]
Randy reindeer, will check pistons first
Like the look of those discs @111 very nice
darkan9el
Pistons fine, have ordered the [url="https://sslrelay.com/buypartsby.co.uk/discsdetails.php?recordID=2306"]Performance disc brakes[/url]
Noel
[quote name='darkan9el' post='392828' date='Nov 3 2006, 05:14 PM']Pistoons fine, have ordered the [url="https://sslrelay.com/buypartsby.co.uk/discsdetails.php?recordID=2306"]Performance disc brakes[/url][/quote]
Nice one... :winky:
webbbr
I've got the very same ones.
Good Job :hehe:
spikes
keep us imformed how well they work / last :)
darkan9el
[quote name='spikes' post='392926' date='Nov 3 2006, 08:53 PM']keep us imformed how well they work / last :)[/quote]
Will do
Keith Bowler
Unless you are doubly sure its your discs I would check the torque setting of your front wheels.
I had a similar problem with my GS but after a routine geometry check at the doctor's (Dr Bones alias Tony) and some re-torqueing of front wheel nuts all was well and has been ever since.
May have saved you a few bob if its not your discs.
Full Colour Version: New Disc Brakes?
