JS820
November 3, 2006, 5:31 am
WOULD SOMEBODY TELL WHAT IS THE PROBLEM IF THERE IS KNOCKING SOUND IN THE FRONT WHEN PARKING OR TURNING AT LOW SPEED?
I'VE REPLACED ALL SHOCKS TO THE NEW FACTORY STOCK, AND ALL FRONT BUSHES & BALL JOINTS, IT STOPPED A WHILE BUT NOW APPEARS AGAIN. IT'S ANNOYING...
aido
November 3, 2006, 5:46 pm
Potentially the brake pads moving around - have they been changed recently?
JS820
November 4, 2006, 4:30 pm
Indeed, I've changed my brake pad from AP Lockheed to Toyota factory stock. The sound comes out even when I'm not stepping on the brake.
Do any one have an idea about what had happened?
chips229
November 5, 2006, 8:14 pm
Did you change just the lower ball joints or did you do the upper ones as well.
The noise could also be coming from the top mounts of the suspension.
Cheers..
Chips.
JS820
November 6, 2006, 4:07 pm
Will check this week and hope the problem can be solved.
goodoldgrandad
November 8, 2006, 8:45 am
If it is when you are at real low speed and on full lock one way have a look in your wheel arches for something catching - I had something coming away from the inner skin on a previous car and on full lock I guess the wheel must have just caught it and it used to beat like a drum!! I'd changed bearings and steering joints before discovering it.
skeet94
November 8, 2006, 9:16 am
JS820 - Did you have the balljoints checked out then?
JS820
November 8, 2006, 3:26 pm
Thanks skeet and goodoldgrandad
i've checked it is nothing related to the inner skin
i've also changed the upper and lower balljoints (actually i've changed the shocks, together with the brushes of anti-roll bar, all the arms in the front). it doesn't help.
I've schedule to change also the brake disc and see if the situation can be improved (but actually I don't think the sound is coming from the disc).
maneesh
November 8, 2006, 4:51 pm
just a thought, engine mount then?
skeet94
November 9, 2006, 1:56 pm
Wouldn't the engine mount actually cause his car to "vibrate" at certain RPM's? Just thinking out loud
JS820
November 12, 2006, 2:27 pm
The engine mount was changed 1/2 years ago. It's now only 12000KM after the change. Therefore shouldn't related the the engine mount.
click here.
