MK4 LS400 having trouble starting
Hi all,
On about 2 or 3 occasions over the last 3 weeks my Mk4 LS400 has been cranking over slow on the 1st attempt and did not start on the 1st attempt when starting it cold. On the 1st try the engine sounded like it wanted to turn over but would just cut out blank half way through, but on the 2nd try it would start fine. I suspected it was the battery and replaced the battery with a brand new 70Ah Bosch AsiaSilver battery.
After replacing the battery all was fine for 1 week until this evening when I tried to start it from cold again. On the 1st 4 attempts the engine did not even try to crank over and all I could hear was a slight “click” sound coming from the engine. On the 5th attempt it started fine like nothing was wrong.
The car only has 62,000 on the clock. Replacing the battery was still a good idea because the old battery was the original Panasonic one and it was due to die out anytime soon anyway and also it has eliminated the possibility of a bad battery.
Any ideas what could be wrong ? Any suggestions would be much appreciated.
Many thanks.
