Full Version: Remote/key Programming
Lexus Owners Club > Lexus Models > Lexus Imports Clubs > Altezza Club
donkammy
guys,
see these advertised on ebay ways of programming the remote/key does anyone have this info to hand
would be intrested in making a spare in worst case senario.
Donkammy
RS Fan
[quote name='donkammy' post='396108' date='Nov 17 2006, 03:34 PM']guys,
Donkammy[/quote]
I think this works with an IS200... anyone know if it works on an Altezza?
"GOT THIS INFO OFF A MATE , IF YOU GET A REPLACEMENT KEY OR THE REMOTE HAS LOST ITS CODE (DEAD BATTERY ETC) FOLLOW THE INSTRUCTIONS BELOW . I HAVE JUST HAD TO DO IT , AND IT WORKS !!
DRIVERS DOOR OPEN AND KEY REMOVED FROM IGNITION SWITCH .
INSERT KEY INTO IGNITION SWITCH , THEN REMOVE IT .
WITHIN 40 SECONDS -
PRESS LOCK AND UNLOCK ON THE VEHICLE DOOR LOCK SWITCH AT 1 SECOND INTERVALS 5 TIMES .
CLOSE AND REOPEN DRIVERS DOOR .
WITHIN 40 SECONDS -
INSERT KEY INTO IGNITION SWITCH .
SWITCH INGNITION "ON" AND "OFF" ONCE TO PROGRAM A NEW KEY CODE WHILST RETAINING THE ORIGINAL CODES OR TWICE TO PROGRAM A NEW KEY CODE WHILST ERASING THE ORIGINAL CODES .
REMOVE KEY FROM IGNITION .
*SYSTEM SHOULD NOW LOCK AND UNLOCK VEHICLE , ONCE OR TWICE DEPENDING WHICH MODE HAS BEEN SELECTED*
WITHIN 40 SECONDS -
SIMULTANEOUSLY PRESS AND HOLD KEY "LOCK" AND "UNLOCK" BUTTONS FOR A MAXIMUM OF 1.5 SECONDS .
WITHIN 3 SECONDS : PRESS ANY KEY BUTTON FOR A MINIMUM OF 1 SECOND .
NOTE --- IF SYSTEM LOCKS AND UNLOCKS TWICE VEHICLE TWICE , PROGRAMMING PROCEDURE HAS NOT BEEN COMPLETED .
NOTE --- A MAXIMUM OF 4 KEYS CAN BE PROGRAMMED .
NOTE --- TO EXIT THE PROGRAMMING MODE : CLOSE DRIVERS DOOR OR INSERT IGNITION KEY .
WELL THERE YOU GO , I HOPE IT HELPS SOMEONE OUT THERE .
GOOD LUCK .
JON . "
babog
[quote name='RS Fan' post='437347' date='May 11 2007, 02:56 PM'][quote name='donkammy' post='396108' date='Nov 17 2006, 03:34 PM']guys,
/quotequote]
nk this works wit ann IS200... anyon knnow if it works on an Altezza?
"GOT OTTISFO OOFF A MATE , IF YOU GET A REPLACEMENT KEY OR THE REMOTE HAS LOST ITS CODE (DEAD BATTERY ETC) FOLLOW THE INSTRUCTIONS BELOW . I HAVE JUST HAD TO DO IT , AND IT WORKS !!
WITHIN 40 SECONDS -
WITHIN 40 SECONDS -
WITHIN 40 SECONDS -
GOOD LUCK .
JON . "[/quote]
/quotequote]
Does anybody no if this works for the Altezza? and were I might source a Toyota key fob with circuitry for an Altezza
thanks in advance
[/quote]
Full Colour Version: Remote/key Programming
