I want the us look on my turnlights, so that the turnlights are always on, but when you use them they go on and off. I tried to do it today with something a mate gave me, it was something i had to put between the turnlight cable, and connect with the standlight cable, then it should give the turnlight always a 6V power, and when you use it it goes from 6volt to 12 volts. Only problem was when i installed it, the turnlight didnt work anymore, and the side turnlight was always on at 6v and worked when you used it (went from 6volt to 12volts brightness)
i disconnected it and now everything is back as normal.
Can anyone help me out is there a way to do this?
here is an example of what i mean:
[img]http://www.radlites.com/images/running%20lights%20truck.jpg[/img]
