QUOTE(fatpieman69 @ Mar 23 2007, 11:09 AM) [snapback]424514[/snapback]
QUOTE(rje_nc29 @ Mar 22 2007, 10:01 PM) [snapback]424445[/snapback]
Just got the car back from a 70k, 7 year service (it's actually done 66k and is 6 years old) with Lexus Park Lane, whose garage is in fact in Battersea. It's a Y reg IS200 with FSH.
- Carry out 7 year 70k service
- Replace pollen filter
- Replace spark plugs
- Supply and fit new cambelt assembly
- Supply and fit new water pump and bypass hose
- Supply and fit new cambelt tensioner
- Change rear brake pads
- Supply and fit new battery
- Supply and fit new o/s/r fog lamp
- MOT
The invoice total was £1,476.51I asked for a new key to be cut and for the boot lifter springs to be replaced but these items needed to be ordered in so neither was done. In some ways I'm grateful or I could have been landed with a £2k bill...
did they have your pants down too!?
over the standard £800 service you had a rear fog light (Clear ones on E-bay £16), battery (£50 from halfords), brake pads (£20 form any motor place). so how did get to £1500?
Ouich!
Yep, my battery was sub £50, my clear rear fogs were £16, my brake pads were £20 for the rears, pollen filter is £33, cambelt and tensioner £80 (rounded up) MOT is around £45, other service parts will come to around £100 including oil, spark plugs oil filter, key fob battery, sump plug gasket. So all I can say is that water pump must be pretty darn expensive!
So the bits in total are around £344.
Service will take a good hour - hour and a half tops....its not a big job...
Fitting battery takes 2 minutes
Brake pads took me 20 minutes and thats jacking the car up one side at a time...
Water pump does not look all that difficult to fit either...
All in all, I think they have some what made a nice little earner out of you....
