Full Version: Hi To All. Turbo Question
Lexus Owners Club > Lexus Models > Lexus Imports > Aristo
gotparts?
whats the biggest size turbo could i run on my stock ecu and injectors? will it be safe? could i run a 67?
skeet94
You could run almost any size turbo, although you'll be limited by the fuel system...and so you won't be able to make more power than 400ish bhp at the most.
Worst case...if you get a boost spike running a 61 or even a 67mm turbo, you'll more than likely run stupidly lean and end up blowing the engine smile.gif. Not worth the risk IMHO...although you can also run Meth injection (Meth is cheaper than race gas!) and you'll be able to run approximately 20-22psi (considering JDM 440cc injectors are used along with Meth) and that would give you some sort of "leeway" with regards to a boost spike. Again you would need some sort of S-AFC and a Meth Injection kit which has a progressive controller.
If you want to do something right, do it the first time around - it's not worth blowing your engine. If you're going to spend £2500 plus on a 67mm turbo, plus manifold, plus wastegate, etc...then why not spend another £1000 and get a proper fuel system? You'll be a whole lot safer and will also have the capability to upgrade later down the road.
Another thing to take into account is the transmission will NOT be able to hold more than 500rwhp - depending on your driving style the transmission may last you for several hundred miles or several thousand miles...unless you're going 6 speed.
Ahhhh__Aristo
QUOTE(skeet94 @ May 21 2007, 09:41 AM) [snapback]439427[/snapback]
20-22psi, T61/67 turbo, stock ecu, stock injectors, meth injection, S-AFC.......
skeet94
I'd read up on some real life experiences with regards to pure 99.9% Methanol injection - it's been done numerous times smile.gif.
You may be talking about Meth Injection consisting of 50/50 meth/water mix... smile.gif. There's people running 25psi on 93octane pump gas (equiv. to 99/100ron UK) and pure meth injection using one of Snow Performance's kits...?
Ahhhh__Aristo
QUOTE(skeet94 @ May 22 2007, 09:04 AM) [snapback]439741[/snapback]
Do you have any links me old buddy?? as my brain won't let me believe 1.5bar on a T67 running stock ecu/injectors with meth and SAFC
skeet94
A-HA! Let me re-iterate that for you...my post should've read T61...I'll post up links when I get off work...
